KANGAROO2 Circle Packing - Different sized circles
This page might provide some clues
http://hydra.nat.uni-magdeburg.de/packing/
Hi Daniel,
Thanks for your sharing. Base on your gh file, I wonder if we can add 2D close curve acts like a “vaccum bag” to achieve a minimal 2D bounday for the circles (see my hand sketch)?
Thanks for any suggestion!
circlenestpuzzle.3dm (31.5 KB) circlenestpuzzle.gh (37.9 KB)
Here’s one tensioning a cable around the outside
wrapcircles.gh (16.6 KB)
circwrap
This way the boundary will form a convex hull of the circles - if you want the boundary to also pull into the concave parts then you’ll need a version with 2d pressure.
There was a component called AlphaShape which would allow the concave boundary between shapes like a vacuum form but I can’t find it on Food4Rhino…
Also, I can’t get it to work on R7
It is out there on this forum if you search alpha shape…
Alpha Shapes 2D
that link from this discussion…
https://discourse.mcneel.com/t/alpha-shape-3d/60651
ah… it was on the Milkbox group on the old forum and by @MateuszZwierzycki I think
Here’s a version using 2d pressure to do a vacuum form which pulls the circles together
wrapcircs2
wrapcircles2.gh (23.2 KB)
Great, thanks Daniel!!
I have done a minor change to the GH, I want to predefine the circle radius and add a grab force to it. But don’t know why the whole bag tend to ‘flow’ to the y axis direction…How can I keep my bag not to flow to one direction, so I can manually adjust the circles and bag’s shape and location?
wrapcircles3.gh (21.1 KB)
It looks like this drifting issue is caused by something unbalanced in the Area goal.
Here’s a version that uses a simpler 2d pressure to avoid this.
There can still be small amount of drift from the collisions too, so I’ve also added a weak PlasticAnchor (which acts as a sort of static friction).
wrapgrab
wrapcircles4.gh (26.5 KB)
Thanks Daniel, but for some reason I cannot get your script running…
Do I need to install any plug-ins?
When open your file, it shows this
You need to tell it where your copy of KangarooSolver.dll is installed.
Either when the error pops up on opening, or by right clicking the red script component and selecting Manage Assemblies.
This file is part of Rhino, and if you have multiple versions of Rhino installed, you need to reference the one from the version you are currently running.
I think this will usually be one of these directories:
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\Components
C:\Program Files\Rhino WIP\Plug-ins\Grasshopper\Components
(if you first installed v7 when it was a WIP)
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\Components
C:\Program Files\Rhino 8 WIP\Plug-ins\Grasshopper\Components
Thanks, problem solved :laughing:
Thanks Daniel for the impressive circle packing2
as Grasshopper newbie I’m having the same assembly reference issue in Rhino7 for Mac,
do you have a suggestion to run wrapcircles4?
Hi @dynmx,
Thanks - see the answer here on setting the reference assembly location on Mac:
top! works :-)>
Hi folks,
Thanks this very usefull thread, I played with these definitions but always noticed there’s a C# component that make me feel like the last of the classroom…wait this remember something.
When it’s about packing like above examples is it the only way to do it?As I know nothing about C# this is a kind of prohibition for me, should I copy paste my schoolmate work, again?..
Circle packing is one of the most-used kangaroo applications, maybe it should become a stand-alone rhino command.
What a great thread!
I used the script you posted @DanielPiker [wrapcircles4.gh|attachment], and its been really fun playing with, but i somehow i am unable to ‘drag’ the circles the same way you do. It might just be a stupid ‘disable window selection’ but i am unable find any setting for that.
whats your magic touch? :slight_smile:
Are you on the latest version of Rhino?
pressing alt probably
no unfortunately not - i tried that before as well.
If anybody has a clue feel free :slight_smile:
