Hi, I tried to make a script for a tent like structure on grasshopper. Its working other than the point i want to drag up in the z axis. that point is not generating in the simulation. its only 2d where i want the point i assigned to go up to create the tent like tensile structure.
posting multiple topics on the exact same issue does not make the issue go away better, it just bloats the web and the people with redundant information. if you found no help after some time bumping the initial topic should be enough.
but as you work with quite big numbers i scaled you geometry by 1/100.
Sometimes if it doesn’t work on your geometry and it work on an example look at the scale. As Strength parameters matters, a big difference in scale needs different strengths parameters. SimpleTentTensile.gh (19.0 KB)
So, just to understand, it was a case of applying loads on the points, and if im not mistaken its also that my scale was huge since it was in mm. right?
