Kangaroo question!
Hello Grasshopper Community,
I am developing a new design for a pavilion and recently started using Kangaroo.
Every time I change the design and Anchoring points for the structure, there is a 50/50 chance it will work or wont. I really believe that it is a problem with the sliders going too high or low. I got it to work before but it wont work once i change the grid !
Anyone can help guide me to the right path ?
Looking at your definition I suspect the issue is that you are setting anchor points which are not connected to your structure - since your anchors seem to be based on something referenced from Rhino, while the rest of the geometry is changed by sliders.
You need to somehow select points which exist as ends of your set of lines after whatever scaling operations you do to them.
Also - there isn’t any need for those sliders connected to Threshold and Tolerance - it should be quite rare that you’d need to change the default values for these.
Awesome Daniel !
You are always amazing with your quick replays. I will try to use points from the Grasshopper definition it self that are extracted from the lines and see if it works.
It worked ! Thank you. Much love !
