Hi all,
I have two questions regarding the example shown in the image below: the “Anchor” configuration for the central area and the “Load” settings for the peripheral area.
Question1:
I am using “Collision One|Many” for the Anchor & Load settings; is there any other way to make the selection?
Question2:
I simply adjusted the TriRemesh length from 10mm to 3mm, yet the calculation results changed. The result with the 10mm length better suits my needs; however, I have a complex model that requires a finer mesh for the calculation. Which parameters should I adjust?
Best Regards,
COCO
Load_test_0630.gh (49.1 KB)
