Hi, I followed a tutorial that connected a mesh from Rhino to springsfrommesh, and then to force objects in kangaroo physics. However, I learned that its no longer available on Rhino 6 and edgelengths is the substitute but when I connected it to force object, there was an error. What did I do wrong and how to fix it? Thank you in advance!
The error message is: An invalid type was connected to the Force objects input, check item
Hi @user315
That’s the old solver component. When using EdgeLengths you need to also use the Kangaroo2 solver.
Thank you so much! But the old solver has anchor points and geometry, may I know what’s the equivalent for those in the new one?
Anchor and Show(used to show geometry) go into the GoalObjects input now:
You can find some more example files with the current version here:
Okay thank you so much for the help!
