Kangaroo 2 Solver Output
I’m creating a mesh using kangaroo 2 but I’m having trouble working with that mesh as an output from the solver. I can use an explode tree from the solver but any other components are experiencing failure- mostly commonly not being able to convert info from a line to mesh. My goal is to use weaverbird Mesh Thicken to add thickness to the mesh. Any help is appreciated, thanks!
Mesh.gh (39.5 KB)
You need to entwine your Goal inputs before connecting them. Then when you use Bang, the tree will have the same structure
