Both I (Rhino 6) and my colleague (Rhino 5) are having an experience where the previewed (and correct) position of a newly mirrored object is not reproduced. When the command is executed, the object jumps several increments to an inaccurate position.
Is this a known bug?
My example is a Va Curtain Wall but my collegue experiences is from time to time with nonVaobjects.
Mirror>Select Object>Select axis point 1>select axis point two>enter: object displays in the correct position for an instant after “enter” before moving to a final incorrect position.
I’ve uploaded the file. The piece of VaCurtainWall and the axis around which I’m mirroring in the example above have been changed to display in red and should be visible in the top view in modelspace.
The red object has a red line beside it. Please try to mirror the object around the line. The Va people recreated the issue, but my colleague without Va has it happen also occasionally, on other objects.
