Hi, I’m trying to remap curves from one surface to another.
I created the second surface using the sweep 1 tool and mirroring it. I’m trying then to join the untrimmed surface to feed into the remap tool. I want them to be accepted as one surface but they are accepted as separate surfaces so the remapping happens more than once onto each separate surface.
Is there a command to join the surfaces into one or is it possible to make this shape using the sweep tool differently?
