I am joining sets of parallel points along curves (see attached); I have successfully done so, but wonder if there is a way which uses less repetitive line components?
I hope you don’t mind me asking this also (I looked around and couldn’t find solution):
Is there also a way to automate consecutive items from ‘List Item’ and ‘Tree Path’ selector components (ie. to select 0, then 1, then 2 - in the ‘i’ and ‘P’ inputs respectively)?
I know I can go inside the ‘i’ and ‘P’ and set multiple inputs and paths manually (see image) but then if I change the the number of curves and line branches elsewhere in the script I would have to come back and manually update the multiple inputs.
Is there a simple way to do automate all items in the list and branch consecutively?
