lewin91
(Lewin91)
1
Hey, I’m following this tutorial, and all was going well until around the 29-minute mark when I tried to do a BlendSrf as Jean does in his video
The problem I’m facing is his edges are joined and mine are not
Here are the edges that I want to blend together:
This is what it looks like in the video once the blend is applied:
The bit I have selected here is half of what I was expecting to have selected when I clicked:
And when I try to BlendSrf:
I feel like I’ve gone drastically wrong somewhere, but I’m not sure where
Any suggestions?
Cheers
wim
(Wim Dekeyser)
2
Hi -
You can use the ChainEdges
option on the command line to select both edges on the upper polysurface.
It seems, that you selected the ‘opposite end’ of the 2nd rail curve. It looks like a diagonal sweep.
lewin91
(Lewin91)
4
Sorry, I’m struggling to figure out how to “ChainEdges”. I can’t find a direct command for it:
-> Unknown command: ChainEdges
So I tried it along with SelChain, but couldn’t figure that out either
wim
(Wim Dekeyser)
5
Hi -
It’s not a separate command, it’s a command-line option for the BlendSrf
command.
lewin91
(Lewin91)
6
Absolutely perfect!
To be clear on what I did:
- Called BlendSrf
- Clicked my working edge
- Clicked on 1 of the split edges
- Clicked on “ChainEdges” in the command
- Clicked on the 2nd of the split edges
- Pressed enter
That has worked great, thank you!
