Joining close by ends of curves
Hi All
I have these curves (they are a deckhouse of a daysailer). I create them using crv2view from top and side drawing. Then I rebuilt the curves to reduce the control point. Now I can easily create all the surfaces, but it gives me tons of naked edges. I assume that by rebuilding the curves moved a little bit and not I can’t get a closed surface…Zooming in on one of the places where 4 curves should come together reveals, that the end of the curves are a little bit apart (see seconds image).
Is there a command to move all the end points so the ends are in the same point?
Thank you very much
Adrian
Hi @Adrian12,
you can either use the _Match command for pairs of curves or turn points on for all 4 curves, select the end points and use _SetPt command and click on the desired location.
_
c.
Thank you very much @clement … it’s all about knowing the command for a task…didn’t know about either of the two, but I’m sure they will be good friends of mine from now :slight_smile:
Note that “Rebuild” doesn’t move the ends of curves, it was your Crv2View workflow that caused that. It’s a tool I basically never use, I just draw my 3D curves in 3D.
