Joined surface will not offset
So the shape with base will not surface offset. All I get is the bits where the edge of the offset would be. However, with no base it works. Why won’t the joined surface offset correctly
Riser.3dm (509.0 KB)
Hi @CalypsoArt
Use DivideAlongCreases (SplitAtTangents=Yes) on the slanted surface and it almost works. There’s a few tiny naked edges at the bottom, but that’s easily fixable by exploding, un-trimming and extending the corner surfaces - see video for details.
HTH, Jakob
I can’t help wondering about the design intent. Do you actually want a sloping top to the rim, or do you really want to offset horizontally, giving a flat rim? If so, then you need to work from curves as the surface offset is always perpendicular.
Step 1. Mark where you want the offset to extend to (or use algebra to calculate the horizontal offset) by offsetting your seam edge by the desired thickness, extending the offset line and intersecting it with a horizontal line from the top of the seam.
Step 2. Create closed curves from the top and bottom edges of the tray.
Step 3. Offset the top curve outwards, setting the distance using the construction from step 1. Then offset the bottom curve outwards by the same distance.
Step 4. Use the bottom offset curve to create a plane, then move the plane downward by the desired thickness.
Step 5. Loft the two offset curves to create the outer sides.
Step 6. Extend the bottom edge of the outer side surface until it is below the plane created in step 4.
Step 7. Trim the excess from the outer side and base surfaces.
Step 8. Use the top curve and its offset to create a plane to form the rim.
Step 9. Join all the surfaces to create a closed polysurface with a flat rim and base.
Step 10. (Optional). Fillet the bottom edge if a rounded edge is desired.
HTH
Jeremy
Also the top rim has sagging corners after offsetting.
You can also simply model with regular NURBS curves and surfaces, either G1 or G2 in the corners. Then offset the surfaces. Then extend them. Finally intersect with 3 planes and trim. Then you can apply fillets, etc.
Once your model is finished, then it’s time to use Join ; )
I guess I don’t get why all that is necessary. I lofted two curves to make the side, used it to trim a plane for the bottom, joined, and then tried to offset the surface. I don’t understand why it would not offset. Moreover, in your process, the offset has an error, and you have to do extends and trims. My question is why is this happening? Is it something in the original loft?
What I do for this is make it taller than necessary, then cut off the extra and so get the flat top surface.
Thanks for the responses. I got to this point lat last night. I was trying to use MirrorHole to mirror the holes to the other side. But that does not work. Also, when I run that command, I can only select the hole from the outside surface of the hole buy not the inside. Why is that?
Netgear_Riser_02.3dm (789.3 KB)
All that… it’s really only a few clicks if you think about it. And you get an accurate result, predictably.
