Hello
Does anyone know how to set the modeling display settings to visualize the joined edges in your model rather than trying to go to ShowEdge command then check naked edges. It will save me tons of time if I can just visually see it in the model
Thank you so much.
Do you know if there is a way you can see the joined edges as object’s colors (as a smooth edges)
My model show all edges as black (as I had already set the surface edges to be black color) but can you differentiate the joined and naked edges with different colors?
Edges are either joined or not… So in the same settings page above, you could for example modify your Surface Edge Settings to a single specific color and leave your Naked edges as “Use object’s color”. That way joined edges will show up as a specific color and naked edges not.
I don’t know why all your edges are black, by default they are object color, check your display modes to see if they have been altered.
Ah I got it. Thank you so much!
