Hi
is there anyone who knows how join these surfaces
thank you so much by advance !!
wskad
join two surfaces.3dm (2.7 MB)
Hi
wskad
You can use ExtractSrf to extract the 2 surfaces and then use join command.
The question is why would you want to do this? Building self-intersecting geometry can lead to problems and isn’t like anything that exists in the real world.
Also some of your surfaces are not quite planar. They have a very small amount of twist which is also likely to trip you up if you if you plan to do more with this.
Hi Pascal,
I want the purple object to hit the larger one at its full thickness
thks
Hi wskad - assuming that you want the purple object, then, to be a sort of continuation of the larger one, I’d go about this a little differently - the big box is slightly tapered to the bottom- that is, the sides are not vertical as the sides of the purple object are - this is going to make the join there a little messy. There are a couple of ways to get at this, if I see what you are after-
ExtractSrf the large face of the larger box.Trim the face with that rectyange and join it back to the box.Line > Extension) of the edges of the large box (green lines in my file) I’d make them a little longer than you want.Sweep2, the rectangle on the lines with maintain Height checked.Trim the object with a plane at the depth you want for it. CutPlane in Right is a good way to get the trimming plane)Join to the boxCap to close off the trimmed end.MergeAllFaces when done to clean up.-Pascal
thank you very much Pascal
I’m trying it tomorrow
Yep, that works as well - I thought it looked like you wanted the surface to extend the existing edges of the box at the top - if your way looks like you want it to, then perfect!
