Darozas
(Darozas)
February 5, 2022, 2:57pm
#1
Hi All
New here !!!
Can any one help me with this challenge.
In Dynamo i can easy achieve this with code block but Grasshopper don’t have one hence me going crazy for last few hours .
All i want to do is use parameter and panel to allow me to add parameter value on end of the string.
If i change to multi line it works. But i do require to keep structure as per below so multi line is not option.
Is this possible
Regards
inno
February 5, 2022, 3:06pm
#2
you can use something like this:
multiline_to_singleline_string.gh (7.4 KB)
where A is set to multiline, and B is a panel that just contains a new line by pressing “enter” once
Darozas
(Darozas)
February 5, 2022, 3:24pm
#3
Thanks for your time
Mostly there. But still have problem as it only works with 2 lines & Biggest issue is that it returning results as list
Regards
inno
February 5, 2022, 3:28pm
#4
could you please post your GH file to better understand what you’re looking for?
Darozas
(Darozas)
February 5, 2022, 3:32pm
#5
Hi Thanks for your time again
All im trying to do is change attributes in Tekla
An looks like there should specific structure to achieve this result
inno
February 5, 2022, 3:43pm
#6
don’t know about the specifics of Tekla, but generally speaking you can use something as easy as this this to transform a Multiline Panel into a single string
multiline_to_singleline_string_Re.gh (6.7 KB)
if you have multiple lines to change alltogether, you can use this from @djordje Replace Text - #5 by djordje
multiline_to_singleline_string_Re_Re.gh (6.8 KB)
Darozas
(Darozas)
February 5, 2022, 4:10pm
#7
Thank for your time
There is node that actually do it all
Regards
