Hi, I tried to join 2 surfaces (I duplicated the edges then loft the inside) and I cannot join them… therefore I have naked edges… ahhh why???
Deleting the inside surface of the ring (the part that would touch your finger, apologies for the jewelry ignorance, I don’t know what that part of the ring is called), and you find a sliver of a surface in the way. Remove that, then use MergeEdge to restore that edge. Re-loft your inner surface using edge curves (you don’t need to duplicate the edges, you can use surface edges as input for loft) and it joins up here.
Hi Eszter - there are several of the tiny sliver surfaces that Sam mentioned, in this model.
Hi Sam, I think it is called the “shank.”—Mark
