Hi Guys
Im quite new to Rhinocommon and i am struggling a bit with something that i want to do.
I want to export all the geometry on each layers seperately to a stp file and then in the end join all geometry and export the joined “hopefully closed” polysurface.
I have come this far by now, but im kinda stuck joining the geometry, does anyone have a trick to do this
Also, am i doing this in the smartest way?
RhinoDoc doc1 = RhinoDoc.CreateHeadless(null); // Creating a headless document for exporting layer contents
RhinoDoc doc2 = RhinoDoc.CreateHeadless(null); // Creating a headless document for exporting the joined content
var options1 = new Rhino.FileIO.FileStpWriteOptions(); // step file write options
for (int q = 0; q < doc.Layers.ActiveCount; q++) // Looping through the layers in the main document
Rhino.DocObjects.RhinoObject[] rhobjs = doc.Objects.FindByLayer(doc.Layers[q].Name); // getting all objects in each layer
for (int i = 0; i < rhobjs.Length; i++) // loop through the objects
GeometryBase gb_tmp = rhobjs[i].Geometry; // get the underlying geometry
doc1.Objects.Add(gb_tmp); // Add the geometry to doc1 for layer export
doc2.Objects.Add(gb_tmp); // Add the geometry to doc2 for joined export
Rhino.FileIO.FileStp.Write(doc.Layers[q].Name+".stp", doc1, options1); // output layer content step files
doc1.Objects.Clear(); // clear out doc1
// TODO: Join all surfaces in doc2 to a closed polysurface
Rhino.FileIO.FileStp.Write("master.stp", doc2, options1); // Output master step file
