Is there a way to only join curves that are going straight in one axis? I added a Boolean Toggle to the Join component, but it still joins the curves that go towards the y axis with the ones that go in x. I cannot find anything about it online.
You will probably need to sort the curve before joining: The ones you want to join together, you should keep them in a particular branch. The rest, in another.
I hope this helps,
Giulio
Giulio Piacentino
for Robert McNeel & Associates giulio@mcneel.com
