Join Brep and Remove internal lines
Hi guys,
Good day, is there a way that I can join the two breps properly having
no internal lines? here is the working gh file.
thanks,
Joel
Join Brep and Remove internal lines.gh (78.4 KB)
If a brep has coplanar faces you can merge them but in your case there are no coplanar faces.
You’d need to rebuild the object with a sweep2 with two rails which have no kinks.
Thank you Martin, what component is the one with R and B letters? thanks.
Here’s a rebuilt brep without internal edges. You could change the tolerance and number of points…
rebuild_brep.gh (118.4 KB)
The component with B and R is a Solid Union component.
