hello! i have lot of pillars in a project and i download a 3d premade ivy to put in it. i was wondering if there is options in lands design to put and play with this type of ivy. i want them to round the columns in random or predetermined ways.
Hi Kiros,
You can use the laGroundcover command to create this kind of plant over the column. You need to do it using vertical closed and planar curves placed around the column. Use different lengths to give a random feeling.
If you know Grasshopper, you could automate this process with any desired variables.
Unfortunately it is not possible right now to do this using a curved surface, or selecting the faces of the column as areas to cover with the ground-covers. This is planned for future versions.
