I've lost the tekla2025 tab in Grasshopper
Good morning,
I usually work with Tekla Live Link 2023 and 2025, but I seem to have lost the tab for connecting to Tekla 2025. I tried reinstalling it, but it didn’t work.
Moreover, I noticed that the folder doesn’t contain the Live Link for Tekla 2023, which I actually have installed and working! So where is it being loaded from? This is a screenshot of my folder now
and this is my grasshopper screen
I’ve checked that the files are not blocked and followed the installation procedure.
What could be causing this issue? Thanks for your help.
Only one link version will be loaded at any time. The loader will try to match this to the running TS version. If it doesn’t find a match and you have more than one link version available, it should show a dialog where you can pick a link version when launching GH.
So this situation means that you have the link version 2023 available somewhere. Also, either Tekla 2023 is running, perhaps in the background OR Tekla 2025 is running but the 2025 link isn’t available (usually blocked, but you’ve checked this).
The 2023 link might be placed in the Tekla 2023 bin folder, that was the case some versions ago. Try this script to see where it might be loaded from:
GetLoadedGHAsScript.gh (17.8 KB)
