Hello Guys so I’m making this simple c# code that moves mesh vertex in an iterative way using a timer that I made internally in script but I can’t seem to get the desired result.
Can anyone help me figure out how to do it ?
Thanks.
Youssef.
4-11-18-IterativeMeshMove.gh (24.1 KB)
What is the desired result?
The mesh point moves inside only once , I want it to move inside once every 500ms for an example
@DanielPiker Here the code made in grasshopper. I’m trying to get the same results buy in C# since I’m gonna be using it for a plugin.
With each iteration the the closest point on the mesh moves to a direction opposite to the repulser point to the closest point vector as the in the pictures with a few consecutive iterations
I hope I answered your question about the desired result .
Thank you.
4-11-18-IterativeMeshMoveUsingGrasshopper.gh (15.5 KB)
I solved the error myself. It figures the recursion was just a loop assigned to a timer that has a count that I use as an end for my loop.
4-11-18-IterativeMeshMove.gh (22.1 KB)
