What is a correct way of iterating over GH_Structure of type GH_String.
I have a bit of code below:
var x = new GH_Structure<GH_String>();
DA.GetDataTree(0, out x);
for (int i = 0; i < x.Branches.Count; i++) {
for (int j = 0; j < x.get_Branch(i).Count; j++) {
//I tried this but does not work . How to retrieve a string value here ?
string s = x[new GH_Path(i)][j].Value;
The structure isn’t aware of the strings inside GH_String, so that step will have to be in your own code. You can iterate over all non-null values using the AllData(true) method on gh_structure I think.
Can’t tell you much without access to my office computer, which won’t happen till tomorrow.
var tree = default(GH_Structure<GH_String>);
// So it turns out AllData() isn't type-safe... disappointing.
var collection = new List<string>();
foreach (GH_String entry in tree.AllData(true))
if (entry.Value != null)
collection.Add(entry.Value);
// Iterate over all paths and branches using a path-index:
for (int pi = 0; pi < tree.PathCount; pi++)
var path = tree.Paths[pi];
var list = tree.Branches[pi];
for (int i = 0; i < list.Count; i++)
if (list[i] != null)
if (list[i].Value != null)
collection.Add(list[i].Value);
// Using two foreach loops:
foreach (var list in tree.Branches)
foreach (var text in list)
if (text != null)
if (text.Value != null)
collection.Add(text.Value);
// Using a direct item accessor (this is *very* inefficient):
for (int i = 0; i < tree.DataCount; i++)
var item = tree.get_DataItem(i);
if (item != null && item.Value != null)
collection.Add(item.Value);
