HI guys,
I am pretty bad in rhinoscript could you look at this? Something tells me I should go to a deeper level than the block istance but I am not sure what to do
objects=rs.GetObjects()
for obj in objects:
#block_id = rs.GetObject("Select block", rs.filter.instance)
# Get the name of the block definition
block_name = rs.BlockInstanceName(obj)
# Get the block definition's objects
object_ids = rs.BlockObjects(block_name)
count= 0
# delete just the curves inside the block
for id in object_ids:
if rs.IsCurve(id)==True:
count=count+1
################################# this is not working
rs.DeleteObject(id)
if count>0:
print "in the block",block_name," ",count," curves were deleted"
else:
print "in the block there are no curves"
