It has strong bends and I need to set the thickness
Hi, I’m a newbie. Please help me. I’m making a curved shape. It has strong bends and I need to set the thickness. I’m working with Revit/Grashopper. I’m getting this error now. How can I fix it?
Also, the next step is to create intersecting trusses on a plane. I’d be grateful for some help with this.
upload .gh file etcetera so we have a look.
unnamed2.gh (25.9 KB)
Thanks for the reply. I’ve taken a different approach now, creating two planes in Revit and connecting them using Grasshopper. But I still haven’t figured out the trusses. I need trusses spaced 4 meters apart, and I don’t know how to do that.
I’m attaching the file with the shape I’m using.
Form.3dm (145.5 KB)
Do not use “Walls” as a category. Use generic models/furniture. (Общие модели, если не ошибаюсь, я давно не работал в ревите)
Also your algorithm does not join your surfaces, your data trees do not match. Flatten inputs to join component. Also no need to provide to the same G shape component both original surface and thickened brep.
