Thanks you
Sorry, it did not work
As @Rickson said, if you don’t sort the list then the objects will be numbered in the order you selected:
def main():
objects = rs.GetObjects("Select objects to label")
if not objects:
return
if len(objects) > 1:
# Get the objects center points
center_pts = []
for obj in objects:
# Get the area centroid for closed, planar curves
if rs.IsCurve(obj) and rs.IsCurveClosed(obj) and rs.IsCurvePlanar(obj):
center_pt = rs.CurveAreaCentroid(obj)[0]
# Get the bounding box center point for all other objects
else:
bbox = rs.BoundingBox(obj)
if bbox:
center_pt = (bbox[0] + bbox[6]) * 0.5
center_pts.append(center_pt)
# Dont sort the center points by their y- and x-values
sorted_cpts = center_pts # [p for p, o in sorted(zip(center_pts, objects), key=lambda k: [k[0].Y, k[0].X])]
sorted_objs = objects # [o for p, o in sorted(zip(center_pts, objects), key=lambda k: [k[0].Y, k[0].X])]
# Parse the prefix
prefix = rs.GetString("Prefix for labels, press Enter for none")
if prefix is None:
prefix = ""
# Label the objects
for i in xrange(len(sorted_cpts)):
# Parse the suffix as zero padded number
suffix = str(i+1).zfill(len(str(len(sorted_cpts))))
dot = rs.AddTextDot(prefix + suffix, sorted_cpts[i])
rs.ObjectName(sorted_objs[i], prefix + suffix)
if __name__ == '__main__':
main()
def main():
if not objects:
return
center_pts = []
for obj in objects:
else:
if bbox:
# Parse the prefix
if prefix is None:
prefix = ""
# Get Start Value
start = rs.GetInteger("Starting Number")
if start is None:
start = 1
# Label the objects
suffix = str(start+i).zfill(len(str(len(sorted_cpts))))
main()
