So in the image, what I am trying to do is trim the bits of the cylinders off of the left side so I have this smooth effect on the left and the more orthogonal bits on the right. The issue is however that no matter what I do I cannot get it to trim or split. I’ve extended all the sides out so that the shape I want extends out of the shape I’m trying to trim and nothing. Somehow the only way it works is if I I move the cylinder even the slightest millimeter up or down, it will split, but it will not split in the exact location that I want it which is extremely annoying. Does anyone here have any suggestions? I’ll leave the file too if it helps.
Hello - there needs to be a complete intersection between the cutter and the victim for Trim to work - I made a surface that extends all the way through your cylinders and not just part way through. Your surfaces had these curves of intersection with the cylinders (ghite):
