I have reopened a script in v.7 of Rhino.inside for Revit, but I am getting weird behaviors (the script does not longer work…).
Among the issues: a valid mesh is shown at the beginning of a connector, but “Null” is returned at the end…?
Even if the data is incompatible (mesh vs curve) shouldn’t the mesh show as arriving to the node?
Hello @gcsucci
Thanks for reporting this. Please make sure you have the latest RIR installed. Kike has fixed a couple of bugs related to the element referencing. For the Element type picker, the component outputs a uuid that uniquely identifies this type across the open models. You can pass the output to a Type component to grab the actual type element:
