Hi all,
After scouring the forums and trying all possible solutions I could find independently with no success, I need to request assistance for this one. The issue is with an installation of Rhino 8 Version 8 SR28 (8.28.26041.11001, 2026-02-10) where it is freezing for an unusual length of time (>30 minutes) upon saving a file or deleting an object within a project.
SystemInfo below:
Rhino 8 SR28 2026-2-10 (Rhino 8, 8.28.26041.11001, Git hash:master @ b7874a05a6982d0419fcc4f6009b510b48a09cb3)
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.24
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) Arc™ Pro 140T GPU (32GB) (Intel) Memory: 2GB, Driver date: 5-25-2025 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA RTX PRO 2000 Blackwell Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-27-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.71
> Integrated accelerated graphics device with 1 adapter port(s)
- Secondary monitor is laptop's integrated screen or built-in port
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-27-2026
Driver Version: 32.0.15.9571
Z-Buffer depth: 24 bits
Total Video Memory: 8151 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.28.26041.11001
Steps taken so far:
Ensured Rhino was added and set to dGPU in Display > Graphics
Ensured OpenGL settings within Rhino were set correctly as per Rhino 8 randomly freezes while doing nothing out of the ordinary - #11 by Japhy and Soooo, you bought a laptop with hybrid graphics and rhino doesn’t run right. READ THIS - Rhino / Windows Hardware - McNeel Forum
Updated Nvidia drivers to latest 595.71version (had 2025 version installed)
Verified power settings were set to Max Performance in Windows and NVIDIA Control Panel
Ran nvidia-smi in CMD; Rhino appeared in the process list, confirming correct GPU is being used
Ensured all latest Windows and manufacturer updates are installed
Confirmed no 3rd party plugins are in use
Projects files are being opened from, and saved back to, a local folder on C:\. Have even tested moving files to a second on-board SSD with no change to behaviour
Does anyone have any further suggestions or similar experiences with this particular CPU/GPU/iGPU combo and using Rhino8?
