I have issues with the graphics of my polysurfaces, that have been blocks, created originally in Sketchup, imported to Rhino. Do I have to re-draw everything, to solve this issue, or can anyone recognize this??
It also comes up as an extra geometry when trying to render in Vray…
Yes, your right @nathanletwory ,though not the main issue i’m afraid.
I’m suspecting the issue is the block/import from sketchup. If everything is exploded into the smallest pieces, and all blocks removed, then it is solved. -This would take an eternity for the whole project though, so if anyone has had this issue before, please share your thoughts.
Actually, you should be able to just run _ClearAllMeshes, then switch back to Shaded mode.
That said your object is very far from world origin, at least Raytraced will not be able to draw it properly, since it can handle only single precision floating point numbers.
