Issues with ClippingSections when cutting nested blocks
I’ve got an issue with the ClippingSections/ClippingDrawings when trying to cut nested blocks.
I want to cut and create a ClippingDrawing of some of the nested blocks but not other.
I am trying to use the selective clipping but the nested blocks seem to follow the mother block layer and ignore the nested block layer.
I would expect the clipping to work in the same manner as they do with layer visibility.
Hej Patrik -
It doesn’t look like this has anything to do with the objects being blocks or not.
I’ve put this on the list for a developer to take a closer look:
RH-84624 ClippingDrawings: Selective Clipping Is Not Selective Visibility
Thanks,
Hej Patrik -
Could you post a simple file that shows what you want to achieve?
