Issues with Arctic view mode rendering not aligning with clipping plan in layout detail viewport
Hi
I am having an issue with the arctic view mode not aligning with a clipping plan in a perspectival view in
a layout detail window. I have attached a PDF to show the issue in the first sectional perspective drawing
on the right-hand side of the page.
Any ideas on why this is happening or how to fix it would be much appreciated.
I have tried using the same clipping plane on a simple box and the result looks as it should so I wonder if it has something to do with the geometries in this particular model itself?
Just for context I am running
Version 6 SR22
(6.22.20028.13281, 1/28/2020)
Commercial on windows
and V-Ray for Rhinoceros 6 4.10.02
test print 9.pdf (1.8 MB)
Hi, can you attach the model so that I can take a look? If you want to send it privately, you can do so here: https://www.rhino3d.com/upload?to=david.eranen@mcneel.com
-David
isnot your model far from origin?
How is this related to V-Ray ?
