Holo
#1
Hi, I am having issues with rs.GetPointOnMesh() where when I click outside of the mesh it returns (0,0,0) instead of “Null”.
Is this intended?
If it is intended then how should I detect if a mesh isn’t clicked on or if the mesh had a vertice at (0,0,0) that was clicked at?
This goes for both V5 and V6
Cheers.
clement
#2
Hi Jørgen,
i think this could be improved in RhinoScript syntax so it does not return a point when no pick was done on the mesh. Below is a possible workaround:
import Rhino
def DoSomething():
id = rs.GetObject("Pick a mesh", rs.filter.mesh, True, False)
if not id: return
mesh = rs.coercemesh(id, True)
gp = Rhino.Input.Custom.GetPoint()
gp.SetCommandPrompt("Point on mesh")
gp.Constrain(mesh, False)
gp.Get()
if gp.CommandResult() != Rhino.Commands.Result.Success:
return
print gp.Point()
DoSomething()
_
c.
Holo
#3
Thanks, I’ll test that out!
