Issue with Rhino 8.24.25281.15001
I have just updated my rhino 8 and now it will not start. It was popping up with issues regarding plug ins such as displacement and 3Dconnexion (3dxrhino.rhp). I have a deadline over the weekend and was wondering if it might be possible to get the download .exe file for a previous version, such as **8.18.25100.11001.
Thanks in advance!
Could you share a screenshot for your current issue? Thank you.
Done, and the link has been sent to you via DM.
Hello Jessen,
Thank you so much! I am now back up and running. I’m not sure what the issue was exactly but a lot of plug-ins were failing, such as:
plug-in 3Dconnexion 3D Mouse.
plug-in Displacement.
plug-in SectionTools.
I’m not sure what might have been causing this, but on top of that rhino would fail to start.
I am getting these pop up when opening grasshopper:
Object: MotionUpdate (level 1)
Exception has been thrown by the target of an invocation.
TargetInvocationException
Object: MotionUpdate (level 2)
Could not load file or assembly ‘System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’. The system cannot find the file specified.
FileNotFoundException
Object: ActionReleased (level 1)
Object: ActionReleased (level 2)
Object: ActionIssued (level 1)
Object: ActionIssued (level 2)
Object: ActionExecuted (level 1)
Object: ActionExecuted (level 2)
Object: ExecutionUpdate (level 1)
Object: ExecutionUpdate (level 2)
Object: ActionCompleted (level 1)
Object: ActionCompleted (level 2)
There is a way to troubleshoot a GH plugin conflict is to start GH from the Rhino command line with command GrasshopperLoadOneByOne, and say No to all 3rd party GH plugins.
I have a similar problem with the same version, where rhino crashes whenever I try to calculate/open a grasshopper script. Could I get the download file for a previous version as well? The one suggested earlier in this thread is probably fine
Another MAJOR Rhino 3d update issue 8.24.25281
Would not run/open in Win 10 and i have NO grasshopper or other plugins just vanialla install
So requested and got 8.23.2521.13001 and it also would not load
so had an older version 8.13.24317.13001 which does load BUT blocks plug-in 3Dconnection 3D Mouse, Displacement & SectionTools.
Might that give a clue what is wrong with these latest updates? and how/what can i send to get the latest version working? When i replied to this message it said SOLVED/SOLUTIOMN but i see nothing that adresses vanilla installations that DO NOT WORK?!
