I can not test as I use Player in one instance, the second instance is after running the simulation model so it takes a few hours so I can not recomute everything
Can you do a simpler test without all the logic you mention?
Just to know where the problem is.
An other test you may do is query the active document outside the cluster an plug it in the Query Elements, to see if this fires the cluster up.
