Issue with project curves to surface
Having an issue projecting some curves.
In this case, projecting loses some lines (in this examples drops 2 out of 20 curves)
Works well in most other cases.
Could use any ideas for a work around.
project-lines.gh (17.0 KB)
when I open your file I get 20 projected curves.
What are your document unit settings in Rhino file?
also, I was wondering if you should move all the curves above/out of the surface your are projecting on, but it is actually working fine when some are below and some above.
Thank you, it was the units. I was working to 0.00005", also called half a tenth. changing this to 0.0001, a 'tenth of a thousandth" in machinist terms, cured it.
Thank you I did not think to check it.
