I have an issue with printing that I can’t figure out.
When I want to print a model in a viewport I hit Command - P. I then get the following dialog box for the “Front” viewport.
As you can see the “Scale” drop down box is editable. It is now set to 1:1. Next to the drop down box is says “100%”. When I print this it is printed true to scale, 1:1
However when I try to do the same thing with the Perspective viewport, the Scale drop down box is no longer editable. It is greyed out. And even though the scale says 1:1, it clearly is not. And next to the drop down box it no longer says “100%”. When I print this, it does not print to scale.
I can’t figure out how to make the scale editable for the Perspective viewport.
