Issue with perspective view in Layout
It happens sometimes first but then persistently. Even when I reset Rhino in v8 and v9 there is an issue with the perspective view in layouts. It will not show dimensions, shadows and the space navigator loses control, everything is shown while tumbling/navigating but is gone when the movement stops. Is this a bug?
Thank you
Perhaps, can you provide your SystemInfo, steps to repeat and a small example file
I open the layout tab “Page 1” and zoom the object into place, then navigate and tumble around in the perspective view of the layout. And for no reason the dimensions and shadows disappear in all view modes and the space navigator turns back to default settings (from object mode to camera mode) even it would work perfectly in Rhino’s normal perspective view. this happens with rhino v8 and v9. Even when I reset to factory settings. Thank you!
File:
Flaechenberechnung Export.3dm (6.0 MB)
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Commercial, build 2025-02-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
Primary OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
Working as expected
I’m not seeing any plugins in systeminfo, although I am on the daily build (8.18), you could try 8.17 that’s available as a service release candidate.
You’re on a newer nvidia driver with a comparable card (i’m on an 8gb RTX 3070 ti). A clean install of the driver might help. (when updating nvidia drivers click Custom and choose Clean Install in their dialog)
@Japhy did a clean install of the latest Dell driver and an update to the latest service release candidate. But the problem remains. It starts well but as long I would navigate in the perspective view shadows and dimensions are gone and the space navigator behaves weird. Any further ideas? As this happens for me also in v9. Thank you
Rhino 8 SR17 2025-2-25 (Rhino 8, 8.17.25056.13001, Git hash:master @ 8d674f13b6b22b7c0498dd9ff031d36e49dcd349)
License type: Commercial, build 2025-02-25
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 11-29-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.46
Primary OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 11-29-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.46
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-29-2024
Driver Version: 31.0.15.5346
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25056.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25056.13001
Hi Hannes
When I open your file, I see there are no shadows nor dimensions.
When I activate the detail and rotate the view, it’s clear that the target is not where one would expect it to be and the objects disappear from the view. Running Zoom Extents gets those “in focus” and brings back the shadows and the dimensions.
2025-03-04 - Detail - ZE
Have you tried navigating with a regular mouse?
@wim thank you, sorry for coming back so late. Yes this solves the issue. Thank you so much. Space Navigator works again.
