Issue with ModifyGeometry()
I’m trying to add a textDot to a bloc with the command ModifyGeometry() but it does not work:
 Dim MyTextDot As New Rhino.Geometry.TextDot("MyText", MyLocation)
 geometry.Add(MyTextDot)
 attributes.Add(attr)
 doc.InstanceDefinitions.ModifyGeometry(MyBlockInstDef.Index, geometry, attributes)
What’s strange is that it’s working fine if I do the exact same thing with a point:
Dim MyGPoint As New Point(MyLocation)
geometry.Add(MyGPoint)
Any Idea?
Best regards
Hi @Matthieu_from_NAVINN,
Here is a Python sample that shouldn’t be to hard to translate to Visual Basic.
https://github.com/mcneel/rhino-developer-samples/blob/6/rhinopython/SampleModifyInstanceDef.py
Does this help?
– Dale
Hi @Dale, this is exactly what I’m doing in VB.net but it only works with a point and not with a textdot as described above. :’(
(By the way, it’s out of topic but it would have been way nicer to just have an Objects() Property for InstanceDefinitions instead of this weird .ModifyGeometry function)
This VB code work in Rhino 5 SR14:
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
  Dim idefName As String = Nothing
  Dim rc = RhinoGet.GetString("Name of block to modify", False, idefName)
  If (rc <> Result.Success) Then
    Return rc
  End If
  Dim idef As InstanceDefinition = doc.InstanceDefinitions.Find(idefName, True)
  If idef Is Nothing Then
    RhinoApp.WriteLine("Instance definition not found")
    Return Result.Failure
  End If
  Dim objects As RhinoObject() = idef.GetObjects()
  Dim geometry As New List(Of Rhino.Geometry.GeometryBase)
  Dim attributes as New List(Of ObjectAttributes)
  For each obj as RhinoObject in objects
    geometry.Add(obj.Geometry)
    attributes.Add(obj.Attributes)
  Next
  Dim origin As Point3d = Point3d.Origin
  Dim dot as New TextDot(idef.Name, origin)
  geometry.Add(dot)
  attributes.Add(doc.CreateDefaultAttributes())
  doc.InstanceDefinitions.ModifyGeometry(idef.Index, geometry, attributes)
  doc.Views.Redraw()
  Return Result.Success
End Function
Not sure how else to help…
– Dale
Hi Dale,
This is what I did in vb.net but it does not work. However I changed my project design and I don’t need this anymore. Thanks a lot for your help.
Regards
Matthieu
