I noticed that there is this rather peculiar behavior with the data structure.
As you can see in the image below, I am trying to merge two lists together. The data structure of the lists I want to merge at the moment are fairly different topologically, and I would have assumed that Simplifying the inputs on the merge component would have made them the same topologically speaking. However, the result from merge is not what I expected.
I know that I can use flatten in this particular case, but I am expecting more branches to come in, and in fact it does not exhibit this behaviour when I have more branches going into the merge component.
Could this be an issue with my understanding of the simplify option in Grasshopper?
