Issue with materials receiving spotlight lighting
Hi. I have an issue I can’t quite solve despite having spent hours trying to find a compatible source of information.
For the background: I am using a layout printout with the displaymode set to Rendered, and I have meddled with the settings to improve display of the shadows. This has worked fine with Rhino 7.
I am trying to create a simple image with spotlights throwing a soft light on the wall but my black wall is acting bananas. The spotlights are identical on brown and black walls, and so are the material features - only the color is different. Both are custom materials with one color picked from the slider, and 0% reflectivity, transparency and gloss.
Why does my lighting look like this?
I assume this is with Raytraced / Rhino Render? If so can you share the file with me for further investigation? If you don’t want to share here on the forum you can use our file uploader: Rhino - Upload to Support - my mcneel work address is prefilled. I’ll receive a notification when the upload has completed successfully.
Btw, in Rhino 8 it is currently better to convert your Rhino Custom materials to Rhino Physically Based since the custom material is broken in some aspects (I am working on fixing what I can there). The Physically Based material is better in every way, though.
Thanks for the fast reply. I will look into the other material types, but after a quick toggle it didnt seem to fix the lighting looking different. All I want to do is edit the spotlight on the right to look more like the ones on the left.
I use the Rendered-display mode in the layout viewport, but im not actually rendering the image. I just print it out from the layout as a jpg. Much quicker and sufficient for my workflow.
If this is a Rendered mode then lets ask @DavidEranen to look at this, since he’s involved in the Rendered mode.
btw I fixed the upload link - I put it in there broken.
I uploaded the model!
Have you tried turning off the Gamma in the render settings? I often find this causes more problems with image banding. It will mean you may have to adjust you global lighting, but it may smooth your graduation on the wall.
Thank you, Giving out a different Gamma-value worked perfectly!
This is indeed due to gamma. The soft light on the very dark wall results in a very subtle gradient, and the gamma causes banding.
