Issue with Loft
Hello everyone,
I’m trying to create a woven pattern on a barrel-shaped surface, but I’m having issues with Loft. It seems the problem is related to how the surface is divided:
With an even number of divisions, I get the error “Loft could not be constructed.”
With an odd number, the geometry is generated, but with errors (see image).
I’ve tried adjusting the Loft options, but the results are not convincing. Any suggestions? I’d appreciate any help.
Thanks in advance!
Forumgrasshopper.gh (18.1 KB)
For even divisions, delete the last item in the list and select the Closed Loft option.
Better to avoid odd divisions.
Appreciate the help! It worked perfectly
Is this a plugin that modifies the capsule to let you do this?
Yes.
Persistent Data Editor | Food4Rhino
