Hi
I test Insert Rhino WIP file to Revit.
There are only basic cube show in Revit 2020.
Please check.
Hi
Hi Travis - is this a Rhino.Inside Revit question?
Which version of Rhino are you saving the .3dm file as? The instructions you linked call for V2.
Have tried opening the saved .3dm file in Rhino?
Hi @davidcockey
I saved as 3dm 7. I intent to try possibility of importing SubD model in file 3dm 7.
Hi Travis -
When a third party application has issues opening a 3dm file, you will have to contact the developers of that third party application. At this point, though, I would imagine that no third party application can read files in the Rhino 7 file format. You could try with a Rhino 6 file format.
Hi @wim
I saved as 3dm 6. this is result:
Hi -
I’d say that is pretty much as one would expect. SubD objects were only an experiment in Rhino 6 and not something that third party developers would spend time supporting.
Once the SDK for Rhino 7 is frozen, it will make more sense for other developers to look into supporting Rhino 7 files. But, for Revit, that is entirely up to Autodesk.
Until Autodesk adds SubD or equivalent to Revit’s native geometry types I would not expect Revit to import SubD geomerty directly.
