I’ve got an issue with rhino event handlers: Everything works fine when I run my project on debug mode, but if I make a release and install it, the events are never raised.
Any idea?
Best regards
Matthieu
We’ll need more details. Obviously event watchers work in Release builds. The sample on GitHub demonstrates this.
https://github.com/mcneel/rhino-developer-samples/tree/6/rhinocommon/cs/SampleCsEventWatcher
– Dale
Hi @dale,
After further investigation, the build method where indeed not the issue. It worked in debug because it targeted my skin with my plugin’s panel already opened, while in release mode I tested it outside of the skin, and the code not finding the panels crashed without reporting.
Fixed with just a few If MyPanel IsNot nothing then ...
Thanks
