Hi All,
When trying to run to a breakpoint after an Exception has been raised (and handled), the editor will not stop on the breakpoint. The example code below shows this.
If I put a breakpoint on the call to “second_function()”, the debugger does not stop on that line.
Have I done something wrong, or is there a problem with the editor?
Thanks for your help.
#! python 3
def first_function() -> None:
print("Start of first_function")
raise Exception("First Problem")
def second_function() -> None:
print("Start of second_function")
raise Exception("Second Problem")
def main() -> None:
print("Start")
try:
first_function()
except Exception as error:
print(f"first_function run: {error}")
print("Between Functions")
try:
second_function()
print(f"second_function run: {error}")
print("End")
if __name__ == "__main__":
main()
