Issue while selecting the trees as geometry
I’m an architecture student currently working on my project to calculate the Cooling Effect of Trees in the City, and I recently started using Land Design with Rhino 7 and Grasshopper. I downloaded the Grasshopper file available on Food4Rhino (link), but I’m experiencing an issue with the geometry.
Whenever I try to select the trees as geometry, it doesn’t work — they remain unselectable (even when i try to select the whole planting layers, it can’t be read by gh). I’m wondering if there’s an alternative method to select the tree objects, or if there might be an issue with the GH file provided on the website.
Thank you in advance for your help!
Best regards,
Hi @skander_rez that Grasshopper script reference the meshes of the Lands Design plants after having exploded them. If you want to reference the plants directly in Grasshopper, and then explode them to run the cooling effect analysis, then you need some more components. I attach a GH file that you can use to obtain the meshes from referenced plants.
Explode Plants.gh (10.9 KB)
