when I insert a model (fileA.3dm) as a linked block into a Rhino file (fileB.3dm), any userdata from fileA is copied to fileB after I save and close. In my case, a ‘document_id’ from fileA gets unexpectedly copied to fileB. please see steps below to reproduce.
Is there a way to prevent this effect? I hope you can help me out.
cheers!
Tim
steps to reproduce:
Open a new rhino document (fileA)
insert fileB testelem.3dm (174.4 KB) containing docUserText/userstrings as a linked block
(command “Insert” and select UpdateType ‘Linked’ and layerstyle “active”)
safe fileA and close
open fileA. DocumentUserText now shows userttext from linked block
This also occurs when attaching worksession files. If you have a file without any DocumentUserText, then worksession in a file with DocumentUserText, it will all get copied over. Then if you detach the worksession file, the DocumentUserText remains. I don’t think this should be the behavior of DocumentUserText because when we have so many different worksessions, it causes a cascade of DocumentUserText to be inserted into a model file that doesn’t use any of it.
