Issue: rs.XformCompare() returns unexpected value
The documentation states rs.XformCompare(xform1, xform2) should return “0 if xform1=xform2”.
When I run the snippet below, I sometimes get return value 0 from when the matrices are not identical (R1). I would expect to either return -1 or 1 in that case
best regards,
Tim
def compareXform():
    for itemA in rs.BlockObjects('block_a'):
        for itemB in rs.BlockObjects('block_b'):
            if rs.IsBlockInstance(itemA) and rs.IsBlockInstance(itemB):
                print 'xform_a', rs.BlockInstanceXform(itemA)
                print 'xform_b', rs.BlockInstanceXform(itemB)
                print rs.XformCompare(rs.BlockInstanceXform(itemA), rs.BlockInstanceXform(itemB))
prints:
> xform_a R0=(1,0,0,46.2819005995964), R1=(0,1,0,156.869812703322), R2=(0,0,1,0), R3=(0,0,0,1)
> xform_b R0=(1,0,0,46.2819005995964), R1=(0,1,0,121.084008261567), R2=(0,0,1,0), R3=(0,0,0,1)
> 0
Hi @timcastelijn,
Yeah something doesn’t seem right. Does this work any better?
import Rhino
def compare_transforms(a, b):
    for i in range(0, 4):
        for j in range(0, 4):
            x = a[i, j]
            y = b[i, j]
            if x < y: return -1
            if x > y: return 1
            if x == y: continue
            if not x == x: # x is a nan
                if not y == y: continue # x and y are nans
                return 1 #  x is a nan and y is not
            return -1 # y is a nan and x is not
    return 0
def test_compare_transforms():
    itemA = rs.GetObject('First block instance')
    itemB = rs.GetObject('Second block instance')
        xformA = rs.BlockInstanceXform(itemA)
        xformB = rs.BlockInstanceXform(itemB)
        print 'xformA:', xformA
        print 'xformB:', xformB
        print compare_transforms(xformA, xformB)
if __name__ == '__main__':
– Dale
Thank you @dale!
