I’ve encountered an unexpected result when I use rs.PlaneTransform.
I have a model with 2 blockinstances (77.3 KB); a normal one and a mirrored instance of the same definition.
I use the script below to align a copy of the world xy plane to the transformed instances, and construct an axes helper based on that transformed plane.
I expected to see a normal and a mirrored version of the same axes helper. However, checking with the left-hand rule, the axis helpers (and thus the transformed planes) seem to be rotated around the y-axis instead
#! python3
def main():
objs = rs.GetObjects(preselect = True, filter= rs.filter.instance)
if not objs:
return
for instance in objs:
xform = rs.BlockInstanceXform(instance)
xy = rs.WorldXYPlane()
plane = rs.PlaneTransform(xy, xform)
z_helper = rs.AddLine(plane.Origin, plane.Origin + plane.Normal * 100)
x_helper = rs.AddLine(plane.Origin, plane.Origin + plane.XAxis * 100)
y_helper = rs.AddLine(plane.Origin, plane.Origin + plane.YAxis * 100)
rs.ObjectColor(z_helper, (0, 0, 255))
rs.ObjectColor(y_helper, (0, 255, 0))
rs.ObjectColor(x_helper, (255, 0, 0))
if __name__ =='__main__':
main()
