ISSUE: RH8 geometry glitch in polysurface
Hi There,
I have a polysurface that shows isocurves extended from the surface itself. Probably related to a “BooleanDifference” operation. The polycurves are not selectable. Does anyone know how to prevent this from happening?
best regards,
Tim
polySurfaceGlitch.3dm (610.0 KB)
Hi Tim -
I’m not seeing that issue here with the file that you attached:
Hi @wim ,
thanks for your response. I have Isocurve display enabled in the display mode. When I disable this setting I also don’t see the effect
(@Martijn )
Yes, if I turn on show isocurves for flat surfaces in shaded, I see the same thing. Looks like a weird display glitch, the surfaces look OK to me.
Hi Tim -
I did look at the model in Wireframe mode with isocurves before posting, but apparently did that after I had run ShrinkTrimmedSrf. That seems to clear this up. If you have any steps to reproduce this behavior from scratch, please let us know.
Hi Tim - @timcastelijn don’t suppose you still have the pre-Boolean version of this, do you? There is some messiness here
Things do not seem to be aligned as I think you expected. There are tiny fragments of the surface with the extra isocurves in there - that is what you’re seeing, it’s not the long narrow faces - those are OK.
Hi There @pascal (@wim),
I don’t have the pre-boolean Breps anymore. However, seeing your diagnose of the geometry fragments, I’ve implemented a new script method for generating the boolean Breps. That solved the issue.
Thanks for your help!
Tim
